3D打印材料PETG的应用
国内
2019
03/18
16:27
Most desktop 3D printer users are familiar with the benefits and disadvantages of PLA and ABS materials. But, when it comes to producing flexible and durable objects, PETG filament is gaining popularity among filament producers and the 3D printing community.
大多数桌面3D打印机用户都熟悉PLA和ABS材料的优缺点。但是,当涉及到生产柔韧性的和耐用性的物体时,PETG灯丝在灯丝生产商和3D打印社区中越来越受欢迎。
The unique benefits of PETG filament for FDM 3D printing PETG的独特性能
•        PETG filament has the reputation of combining the functionality of ABS (stronger, temperature resistant, more durable) and reliability of PLA (easy to print) in one material.
PETG 3D打印耗材结合了ABS耗材的功能性(强度好、耐温高、耐用性高)及PLA的可打印性。
•        The layer adhesion is usually excellent.
优秀的层粘附性
•        Reduced potential of warping or shrinking of your prints.
减少类似ABS产品带来的翘曲
•        Also, you can recycle the material, along with prints and misprints. However, don’t take this as permission to start printing irresponsibly – sustainably speaking, PETG filament is still a plastic that should be utilized and recycled properly.
从可持续的角度来说,PETG耗材是一种应该被合理利用和回收的塑料
When Should PETG Filament Be Used?
PETG的应用
It is a good all-around material but truly stands out from many other filaments due to its flexibility, strength, and temperature and impact resistance. This makes it an ideal 3D printer filament to use for objects which might experience sustained or sudden stress, like mechanical parts, 3D printer parts, and protective components.
它是一种很好的全能材料,但是由于它的柔韧性、强度、温度和耐冲击性,它确实从许多其他耗材中脱颖而出。用于对象可能经历持续或突然的压力,如机械零件,3D打印机零件,和保护组件、工装夹具等。
HOW DOES PLA COMPARE TO PETG FILAMENT?
PLA 与PETG 的对比
•        PLA is easier to 3D print and handle than PETG filament. Also, PLA is also more forgiving when it comes to 3D printing errors.
PLA比PETG丝更容易进行3D打印和处理。此外,PLA 3D打印出现问题时也容易得到客户的宽容。
•        Both materials show minor shrinkage during cooling.
这两种材料在冷却过程中都有轻微的收缩
•        Both are considered to be food-safe.
两种材料都是食品级的安全材料
•        Also, both are user-friendly, but PETG filament is more durable, stronger, and can handle stronger impact.
两种材料都容易打印,但是PETG更加耐用、更强,耐冲击性更好好
•        PLA is less prone to scratching and surface damage.
      PLA不容易刮伤和表面损伤。
•        PETG filament is generally more expensive than PLA.
PETG 价格更高
•        PLA filament offers more way more variations.
PLA耗材更多选择
How does ABS filament compare to PETG filament?
ABS 与 PETG相比
•        Both materials are highly durable, offer good strength and impact resistance.
两种材料都拥有很好的耐用性 ,提供很好的强度及抗冲击能力
•        ABS is more flexible, with minor bending before snapping
•        ABS韧性更加好,在断裂前有轻微弯曲
•        ABS is not food-safe. When handled properly, PETG filament is.
•        ABS 并非食品安全及产品, PETG 安全性更高
•        ABS needs a heated bed for 3D printing.
•        ABS打印的时候需要加热底板,并且容易翘曲
关于科莱恩
3D 打印耗材
•        使用高品质的聚合物原材料,确保耗材的卓越性能;
•        使用科莱恩添加剂,提高耗材的性能并可满足各种终端应用需求;
•        耗材的颜色丰富多彩,并可定制颜色及配色;
•        耗材均由科莱恩的高端生产线生产,确保始终如一的高品质。
Glycol modified polyethylene terephthalate (PET-G) 是一款具有很好的韧性及耐化学性的聚酯。PET-G耗材所打印出来的成品具有很好的层附着力,适用于打印各种部件,包括终端使用部件、原型、夹具、固定器等。科莱恩通过使用合适的添加剂,如Hostanox® P-EPQ® 及 Hostavin® ARO 8等,提高耗材的热稳定性及抗热氧化的能力。
性能优势
•        高强度及硬度的热塑性工程塑料
•        透明度高
•        良好的抗冲击强度
•        良好的耐化学性
性能优化
•        降低热氧化降解
•        最大限度地减轻由紫外线引起的黄化
推荐应用*
•        原型
•        工装夹具,固定器
•        容器/ 包装材料
•        机械和技术应用部件
*根据具体的产品应用而定
3 D打印耗材应储藏在阴凉干燥的地方,最好可放置在温度5 - 25°C之间的密封的容器里,并放入科莱恩Pak®干燥剂。如果材料已经吸入水份,请把材料放入真空干燥器或者干燥剂干燥装置里,在65°C的温度上烘4-6小时。从装运日期起,如妥善保存,最低保质期为1年。
包装优势:
科莱恩耗材的线卷使用PC材质,可以直接放在干燥箱上进行干燥
科莱恩Desipak 干燥剂 ,可确保耗材在密封期间保持干燥
科莱恩湿度显示卡,可检测耗材是否处于干燥状态
材料打印条件均在线盘上显示
上一篇:蔡司COMET 5-4M 三维数字扫描仪产品详解
下一篇:未来热门创业,广告发光字3D打印机的发展方向
