3D printed Hand by Frankie Flood打印假肢模型分享
展翼计划
12:35
模型
该假肢模型名称为3D printed Hand by Frankie Flood(该模型仅用于公益,不可用于商业用途)
是fflood在2014年4月23日上传至Thingiverse网站的目前项目还在更新中。原文地址为(有可能被墙):https://www.thingiverse.com/thing:308124
数据文件下载链接:https://pan.baidu.com/s/102vjDhi6TF4RvOQHiVZPAw   提取码:qjj6
以下为谷歌机翻,不喜勿喷~原文后附。
这是机器人野兽机械手掌的混音。我早期遇到了一些问题,原始网格上有漏洞,拇指在手的早期版本上停止了,因此我决定从头开始构建一个我可以在Rhino 3D中轻松编辑的版本。 Rhino 3D软件目前正在为Mac开发,所以它是免费下载的。我已经将犀牛文件包含在构建阶段中,因此任何人都可以编辑或返回并从我创建的原始曲面开始构建此模型。我还包括了parasolid和3Ds文件以及标准的stl文件。我使用了爪子手指并修改了“停止”区域中爪子的近端部分,这些部分击中了手掌以防止手指过度伸展。非常感谢Jorge Zuniga在最初的Cyborg Beast上所做的工作
原文:
This is a remix of the cyborg beast mechanical hand palm. I had some issues early on with holes in the original mesh and the thumb stop breaking on an early version of the hand, so I decided to start from scratch and build a version that I would be able to edit easily in Rhino 3D. Rhino 3D software is in development for Mac right now, so it is a free download. I have included the rhino files complete with building stages so anyone can edit or go back and start with the original surfaces I created to build this model. I have also included parasolid and 3Ds files along with the standard stl files. I used the talon fingers and modified the proximal sections from the talon in the "stop" area that hits the palm to keep from overextending the finger. Many thanks to Jorge Zuniga for his work on the original Cyborg Beast
上一篇:展翼计划3D打印义肢,强生公司、三的部落在行动
下一篇:Reborn Hand假肢模型分享
