Unique bulk metallic glass shows low-cost 3D printed jewellery potential
3D printing news
2021
06/18
15:08
A Swiss research team has formulated a novel bulk metallic glass (BMG) with the properties needed to be 3D printed into high-quality precious metal parts.
Using a palladium (Pd)-based BMG powder and conventional LPBF 3D printer, the engineers have been able to fabricate crack-free samples with a density of 99.6%, and a natural mirror-like finish. Given that the team’s prototypes required less than 70g of material to print, they could act as a precursor to an affordable new range of additive manufactured jewellery and watchmaking components in future.
The researchers’ initial 3D printed BMG samples (pre-parameter optimization). Photo via the Applied Materials Today journal.
BMGs in jewellery production
Due to their high corrosion and oxidation resistance, as well as their non-allergic nature, pure precious metals are in many ways ideal materials for manufacturing jewellery. However, such alloys also tend to exhibit low resistance to wear and scratching, and these are critical deficiencies when it comes to creating high-value consumer products.
Although substantial research has been conducted into developing precious alloys with better properties, this has previously proved difficult even after several thermo-mechanical treatments. BMGs, by contrast, are increasingly being viewed as a promising alternative to crystalline parts due to their amorphous nature, which prevents them from being impacted by dislocation and grain boundary defects.
While the very first BMG dates back more than 70 years, these structures are often created via conventional casting, limiting the size of the parts it’s possible to produce. Using LPBF 3D printing, meanwhile, it’s theoretically feasible to print BMGs while preventing their crystallization, yielding durable amorphous parts, but the process has so far only been applied to metals like iron and aluminum.
To evaluate the full potential of additive manufacturing in the production of premium gold and silver-based BMGs, the Swiss team has therefore sought to identify the optimal parameter set for creating highly-amorphous palladium structures, in addition to the tipping point at which heat variance causes part shape and geometry irregularities.
The single line tracks used by the Swiss team to identify the optimal 3D printing parameter set. Image via the Applied Materials Today journal.
Optimized precious metal printing
Initially, using single line tracks, the researchers were able to determine the ideal parameters for their experiments, which turned out to be at a laser power level of 40-60W, with anything higher than 80W resulting in print deceleration. Having identified the optimal set up, the team proceeded to fabricate twelve samples each measuring 5 x 5 x 1mm3 , but early prototypes exhibited highly-irregular shapes.
To correct this distortion, the researchers introduced a one-second wait between the printing of each layer, giving the samples time to cool between successive laser tracks. Interestingly, upon later dissection, each of the test specimens featured an amorphous in structure, but the part produced at 60W proved to have the widest processing window, validating the team’s earlier hypothesis.
Leveraging their final parameter set, the engineers wrapped up their tests by 3D printing a 3mm x 4mm cylinder, which exhibited a porosity volume of just 0.4%. However, the team did concede that their results could be affected by the resolution of their μCT scan, and that the specimen’s compressive strength was 14% less than casted alternatives, proving the need for further process optimization.
What’s more, summary kinetic analysis revealed that the researchers’ parts crystallized more slowly than they could be processed, suggesting that cross-contamination and powder atomization may have impacted on their findings, thus the issue warrants investigation before such BMGs can be deployed as an end-use precious metal substitute.
“Despite the good glass-forming ability of Pd-based BMGs, the critical aspects in LPBF fabrication for avoiding crystallization are not so much the thermal conditions, but the absence of impurities,” concluded the team in their paper. “[Our] work illustrates how the combination of precious metals, amorphous state and AM can lead to promising applications, especially in the jewellery and watch industries.”
A direct comparison between the team’s pre-and post-parameter optimization results. Image via the Applied Materials Today journal.
The multifunctionality of BMGs
Given the inherent malleability and corrosion-resistant qualities of amorphous alloys, it’s no surprise that significant research is now being conducted into developing defect-free BMGs. At the Huazhong University of Science and Technology (HUST), for example, researchers have formulated a powder of their own, that can be 3D printed into scalable BMG structures.
Just last year, Chinese scientists also developed a combined ultrasonic vibration-assisted, thermoplastic forming and 3D printing approach to producing reinforced BMG composites. Using the novel process enabled the team to create sandwich-structured titanium alloy-reinforced parts, which proved to be much tougher than conventional monolithic BMGs.
Elsewhere, Fabrisonic has iteratively developed its Ultrasonic Additive Manufacturing (UAM) technology, which is capable of merging different amorphous alloys. Working as part of a recent NASA study, the firm was able to join dissimilar metals to crystalline substrates, lending them enhanced strength, corrosion-resistance and potential aerospace applications.
The researchers’ findings are detailed in their paper titled “Additive manufacturing of a precious bulk metallic glass.” The study was co-authored by Navid Sohrabi, Jamasp Jhabvala, Güven Kurtuldu, Ruggero Frison, Annapaola Parrilli, Mihai Stoica, Antonia Neels, Jrg F. Lffler and Roland E.Logé.
During the project, research was conducted collaboratively between Swiss Federal Institute of Technology Lausanne (EPFL), ETH Zurich and Swiss Federal Laboratories for Materials Science and Technology (EMPA).
To stay up to date with the latest 3D printing news, don’t forget to subscribe to the 3D Printing Industry newsletter or follow us on Twitter or liking our page on Facebook.
For a deeper-dive into additive manufacturing, you can now subscribe to our Youtube channel, featuring discussion, de-briefs and shots of 3D printing in-action.
Are you looking for a job in the additive manufacturing industry? Visit 3D Printing Jobs for a selection of roles in the industry.
Featured image shows the researchers’ initial set of 3D printed BMG samples. Photo via the Applied Materials Today journal.
南极熊3D打印网https://www.nanjixiong.com/转自来自网络:https://3dprintingindustry.com/news/unique-bulk-metallic-glass-shows-low-cost-3d-printed-jewellery-potential-191697/
上一篇:Shapeshift 3D and CCM partner to custom-fit 3D printed hockey helmet liners
下一篇:Reaching the PEEK in additive manufacturing
下载手机APP
