Carbon Dioxide Laser Marking Machine
03/18
13:50
Carbon dioxide laser marking machine adopts imported carbon dioxide laser, equipped with German high-speed scanning mirror and beam expanding focusing system, marking precision is high, speed is fast.Laser height adjustable, easy to use, can be replaced with a variety of marking format lens;Continuous operation, long working time, clear and beautiful marks, powerful software function, flow mark, flight mark;Fixed laser marking design, simple operation, equipped with a perfect ventilation system, no odor, environmental protection and safety.
CO2 laser marking machine using infrared light band,10.64um gas laser, CO2 gas charge into the electric tube to produce a discharge, so that the gas molecules released laser, laser beam, laser beam to be processed surface gasification to achieve the purpose of carving.CO2 marking machine USES two kinds of luminous tube: glass tube and metal tube, the performance of the metal tube is relatively stable, the service life is longer, and the price is also relatively higher.It's basically maintenance-free.But the glass tube CO2 laser marking machine needs to replace the glass tube regularly, the use cost is low, but the late replacement laser is more troublesome.
The scope of application of CO2 laser marking machine is narrower than that of fiber laser marking machine, it can only mark a variety of non-metallic materials, such as bamboo products, wood, paper, acrylic, leather, glass, rubber and so on.Mainly used in medicine, such as medicine paper packaging box, medicine glass packaging;Cosmetics industry, such as paper boxes, glass boxes, plastic boxes, etc.Tobacco industry, such as each cigarette to label the area code;Packaging of food and beverage;On the packaging boxes of alcoholic drinks;Garment accessories;Electronic components, such as capacitance on the label such as the certification mark;Signs on building materials, etc.;All kinds of LOGO text information.The application industry is very extensive.
Sample picture
file:///C:\Users\ADMINI~1.USE\AppData\Local\Temp\ksohtml324\wps1.png
Compared with the traditional ink-jet code printer,CO2 laser marking machine features faster speed and higher marking efficiency. The working principle of exposing deep substances through the evaporation of surface substances makes the anti-counterfeiting performance significant, which cannot be wiped or changed.Its service life can be more than 50,000 hours, and the late basic zero maintenance, completely can rest assured long time use.The software is easy to operate, friendly human-computer dialogue, and what you see is what you get. It has a wide range of applications and can meet the requirements for marking and coding of a variety of materials.
CO2 laser flight marking machine, it is suitable for almost all non-metallic materials of the flight line of the code marking, this equipment has the technical characteristics and the application of the field is so broad, so that this equipment in all marking machine has a large market share.
