找回密码
 注nanjixiong2017册
QQ登录
只需一步,快速开始
发表帖子
Tensorflow BasicLSTMCell 初始化参数
[复制链接]
参数:
num_units:int,LSTM cell 中 units 的数量
forget_bias:float,添加到遗忘门的偏置项。
state_ist_tuple:如果为真,接收并返回 states 为2个 tupules,一个是 `c_state` 一个是 `m_state`。如果为假,把他们连接起来在列的维度。第二种操作很快会被废弃。
activation:内部状态的激活函数。默认为‘tanh’
reuse:Python 布尔值描述了是否重用一个已经存在的“scope”内的变量。如果不为真,而且已经存在的“scope”已经有给定的变量,会出现一个错误。
Args:
      num_units: int, The number of units in the LSTM cell.
      forget_bias: float, The bias added to forget gates (see above).
      state_is_tuple: If True, accepted and returned states are 2-tuples of
        the `c_state` and `m_state`.  If False, they are concatenated
        along the column axis.  The latter behavior will soon be deprecated.
      activation: Activation function of the inner states.  Default: `tanh`.
      reuse: (optional) Python boolean describing whether to reuse variables
        in an existing scope.  If not `True`, and the existing scope already has
        the given variables, an error is raised.
class BasicLSTMCell(RNNCell):
  """Basic LSTM recurrent network cell.
  The implementation is based on: http://arxiv.org/abs/1409.2329.
  We add forget_bias (default: 1) to the biases of the forget gate in order to
  reduce the scale of forgetting in the beginning of the training.
  It does not allow cell clipping, a projection layer, and does not
  use peep-hole connections: it is the basic baseline.
  For advanced models, please use the full @{tf.nn.rnn_cell.LSTMCell}
  that follows.
  def __init__(self, num_units, forget_bias=1.0,
               state_is_tuple=True, activation=None, reuse=None):
    """Initialize the basic LSTM cell.
    Args:
更多教程:
http://www.tensorflownews.com/
使用道具 举报 回复
您需要登录后才可以回帖 登录 | 注nanjixiong2017册
本版积分规则
